Why does the PC display disk usage of 100% for about 10 minutes?
When I power on the PC it displays 100% disk usage for 10 to 15 minutes. How can I fix this ? And may I install SSD and HDD in the same time?
Es esta una buena pregunta?
Hi @gojo_1,
I can't really diagnose the 100% usage problem off hand. Does it say 100% and then go down, or is it 100% all the time? Remember that the more information and detail you provide, the easier and better we can help.
According to Dell, the 3550 supports up to one M.2 2230/2280 SSD and one 2.5" HDD (both <=2TB).
Fue útil esta respuesta?
Thanks for your help,but I said that it go down 10 or 15 min after power on .and about the supporting can I install the two in the the same time and I didn't understand "(both <=2GB)"
And thank you so much for your halp
@gojo_1 Yes, but it was a bit hard to tell what you mean. How much "goes down" after 10 to 15 minutes?
According to Dell, you can have both installed.
"both <=2TB" means that both discs (M.2 and HDD) can be Less than or Equal to 2TB in size.
FYI; Mathematical expressions:
<2 Means Less than 2
<=2 Means Less than or equal to 2
>2 Means Greater than 2
>=2 Means Greater than or equal to 2
Do you mean 2TB ,the problem I didn't understand the 2GB
@gojo_1 You are absolutely correct. 2TB not GB! (I have updated the answer and comments)
You shocked me 😂 just for confirming I can install SSD +HDD in the same time
You probably have some process, program or programs running in the background. Perhaps you have too many apps autoloading?
For the general user running a program like "Tweaking.com" is the best start. Follow directions carefully about safe mode, do all the steps and do the full scan. Let us know how it goes.
The app that autoloading it the system apps like system host...etc
Hi @gojo_1 Windows Update may help. Try doing that. There were some problems with Windows Explorer that they fixed with a resent update.
I did it and still the same issue
Does it happen if you start the laptop with a clean boot?
What this clean boot do?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 131
