Saltar al contenido principal
El HP 15-bs115dx se puede identificar por su número de modelo: 3MP96UA. Fue lanzado en 2018. Tiene un procesador Intel Core i5-8250U, 8GB de RAM y un disco duro de 1 terabyte.
Which screen is compatible with hp 15-bs110ne
hi , I'm surprised that my laptop model wasn't on the list or mentioned in any way
"hp 15-bs110ne" , I have many white spots on the screen as a result of cleaning the laptop with "D-40 Specialist Electrical Contact Cleaner" , I've only sprayed under the keyboard
But apparently, after leaving the laptop for 72h to dry, the liquid has escaped to behind the screen and made white spots.
Now I'm trying to fix the screen if that is possible or replace it as the last case
could you please tell me if that is fixable? if yes how ?
if it's not fixable, could you specify which hd display 5.6in that would be compatible with this specific laptop ?
thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
its not repairable, take the lcd panel out and there should be a model number on it
Fue útil esta respuesta?
Puntuación 1
Hi @mymyit
Here's the maintenance and service guide taken from this support webpage for the laptop.
Go to p.72 to view the necessary pre-requisite steps and then the procedure to remove the display assembly to get to the LCD unit.
Go to p.23 Item #3 to view all the compatible LCD units and their part numbers. Search online using the part number only to get results for suppliers that suit you best. The part number should be somewhere on the back of the LCD unit in your laptop, if you wish to verify that you're getting the same one.
Puntuación 1
Añadir tu respuesta
SmartIt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 139
