Mic not working after opening iMac
After replacing the hard drive. All went well BUT -now my mic does not work. It's the single hole on the bottom. Any ideas anybody? I made sure the hole was not covered up.
Es esta una buena pregunta?
I'm sure you have a simple problem! Many tape setups sold failed to address the needed gap for sound to reach the mic. Review Step 3 in this guide Reemplazo de las tiras adhesivas del iMac Intel 21.5" Retina 4K Display (2017) Sadly once the tapes are are you can't really reuse them so you'll need to get a fresh set iMac Intel 21.5" (2012-2019) Adhesive Strips
Fue útil esta respuesta?
Thanks Dan for your reply. Yes I had to open it up again and saw immediately the problem. I did in fact hide the mic with the tape. As there are 3 holes- One in the middle is the mic. I had an extra set of tape and this time cut the 4R tape in area around the 3 holes, maybe 1/2 inch in width. So none of the 3 holes have any adhesive. I doubt all but that tiny section will cause the screen to fall. Anyway put it all back together and the mic is working fine.
@Paolo Alberto - Happy it worked out! Don't forget to score the answer & accept it - Thanks!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 115
