Replacement battery is dead
I replaced the battery in my late 2013 15" MacBook Pro a few months ago, worked fine until this morning. Suddenly the battery is completely dead as in nowhere to be found. The only way to get my macbook to work is by plugging it in, unplugging immediately turns it off.
Es esta una buena pregunta?
6 comentarios
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
- de Dan
Thanks, Dan. Interestingly it can't even find and read the battery:
- de chrregul
Please post an image of your results when you click the "Battery info" tab when using Coconut Battery.
- de mayer
i need a little more info did u calibrate the battery
- de hay yew
Thanks for your answer, and yes, I did. It worked very well until this morning. I opened up my computer to see if the cable connection between battery and logic board was loose. Unplugged and plugged it in again. No change.
- de chrregul
Mostrar 1 comentario más
