Saltar al contenido principal
Procesador de 1.4GHz o 1.6GHz, SSD de 64GB o 128GB.
Preguntas 160 Ver todo
Can We Change the Lcd only?
Hello my macbook air got liquid damage at display . it shows sign in display. Can i change the lcd part only . case is like unused becoz i kept it in a Bag always. is there any way to remove the Bezel and change the lcd only . becoz the whole display clamshell is expensive than lcd only. thnx in advance
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Solución Elegida
Yes you can. You will need to follow the iFixit guide to removing the display assembly, then this guide for replacing the LCD. You will need the manufacturers part number to know what LCD to purchase. To get the LCD part number type in or copy and paste the following string in to the terminal:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
After executing the command you should receive a set of digits and numbers. If you want to determine the manufacturer of your display, simply take the model number generated in Terminal and type it into Google. Usually various OEM part listings will show the name of the brand for your particular LCD screen.
Fue útil esta respuesta?
Puntuación 7
5 comentarios:
This guide is for MacBook air 13inch old model. i have a late 2010 Macbook Air 11 inch. is this guide same as for new one ?
- de
Here is a video of the procedure on the newer 11 inch. http://www.youtube.com/watch?v=eHNtnvzfS...
- de
thanx for the video link.
- de
Sorry I know this thread is really old but could you potentially use this command for other things connected to the computer?
- de
@tylerkeeton17 - How about posting your own question with the details on what you are looking for. You'll need to give us more here.
- de
How can you type that command to check the model number of the screen if your screen is broken??
Puntuación 0
5 comentarios:
- de
this is very difficult to check out. one more thing . these leds are very difficult to find or get. just go to apple service centre and let them fix this or just find the display clampshell on the ebay.
http://www.ebay.com/itm/APPLE-MACBOOK-AI...
- de
I used the guide provided by ABCellars and managed to replace the Macbook Air LCD panel. Unfortunately the video doesn't exactly match the assembly I worked with. In my case, the LCD panel was glued to the frame. The back-light and diffuser assembly is separate and it was glued as well. Fortunately, I managed to remove the LCD panel without damaging the back-light assembly. Just a few small scratches while removing the broken glass of the LCD. Perhaps the most complicated screen replacement in my experience. Thanks for the guide, it helped.
Puntuación 0
Añadir tu respuesta
SIMRAN estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 12,413
