Saltar al contenido principal
Braun MGK3060 Juego de recorte de precisión 8 en 1 para el rostro y la cabeza
Preguntas 5 Ver todo
I put 220 volts on it and the electronic map burned out
type 5514 .. I put 220 volts on it and the electronic map burned out
The transistor has burned out.. where can I find its type and number
Update (05/11/2022)
Update (05/11/2022)
i think two transistor problem 😓
Es esta una buena pregunta?
Puntuación 0
4 comentarios
@maheralafndy post some good picture of the damaged board and component with your QUESTION. That way we can see what you see and hopefully find what you need. Agregar imágenes a una pregunta existente
- de
@maheralafndy can you post a picture that was taken straight to the board? Makes it easier to look at the components and traces as well as the other side. Wash the board off with some isopropyl alcohol or similar and a soft brush. Looks like some major damage and I wonder if this is not more than just a transistor....
- de
@maheralafndy Could you fix it? I've made that mistake too.
- de
hello ... no ..I buy my comfort and got a new one ..11$ 😅 philips
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@maheralafndy check this guide Sustitución de la batería de la recortadora Braun 5514 and it might help to identify the parts. your board will most certainly need all of those components replaced. Looks like a few diodes, capacitors and more. We need to really get a close look at it.
Okay, so I would focus on D1 D2 R12 T3 and the broken trace from T3 to D2. We still need to see if there is any damage on the backside of the board. D1 and D2 are SS24 Schottky 40 V 2A Surface Mount DO-214AA Diodes.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
maher alafndy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 125
