iPad 7 Rapid Battery Drain
Hello
I repaired a clients iPad 7 and it came back back with in 2 days with "rapid battery drain"
Pre and post repair I checked that the battery charged at least 5%.
I did confirm that after getting the iPad back that it will loose 100% charge over night in stand by.
I checked the battery on 3u tools and it said 87% capacity / life.
I replaced the battery any ways as 3u isn't always correct and the "new" battery (taken from a donor iPad) was 95%
Same issue
I tested with an original screen (one i removed with out breaking) with the same issue.
Home button flex is all original
The full restore and update was done with the same issue
Any idea's?
Note - I can't prove / disprove the iPad wasn't doing this before I received it for repair as I only ever make sure it charges at least 5% as prev mentioned
Thanks
Es esta una buena pregunta?
