Saltar al contenido principal
Calculadora científica de Casio. Ampliamente utilizada por estudiantes de todo el mundo debido a su gran calidad por el bajo precio.
Why it is hang after pressing √(10) *10^13
How to unhang calculator
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Remove Battery
Since you can't interact with the calculator at all, start with removing its battery by following the guide I have added below. You can skip replacing the battery, just put the same battery back again.
This will force the calculator to turn off.
Sustitución de la pila de botón de una Casio FX-991ES Plus
If problem continues
If it still freezes when you do that, redo the process of removing the battery and then do the following steps to factory reset the calculator.
When the calculator is on.
Step 1: Press SHIFT and then 9
Step 2: Press 3 to select the "Reset All" option
Step 3: Press = to confirm
Step 4: Press the AC button
Hope it works after this! :D
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Not fixed
My calculator is hang and it is not resetting .
And not pressing any button
- de
@Abhinash Shah Ohh, okay! I have updated my answer, hopefully, it will help to remove the battery to force the calculator to turn off and then performing the reset process.
- de
Añadir tu respuesta
Abhinash Shah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 995
