Some Buttons don't always work.
On my keyboard there are some buttons that don't work properly. Sometimes they work and sometimes they don't.
Es esta una buena pregunta?
I would try cleaning underneath your key caps and see if you can get your keyboard to function afterwords. The best way to do this is to remove the key caps from the keyboard itself. There is a guide on how to do this that I will link here.
I would also check to see if the ribbon cable that connects the keyboard to the logic board is seated correctly and is not damaged (I.e. any creases in the cable). If none of that works, it could be that the switches for the keys are damaged in some way, which means you would need to replace the keyboard.
Definitely try to clean the board first, and make sure that the cable is good first before looking for the replacement.
Fue útil esta respuesta?
Thanks for your reply I will try this now
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 436
4 comentarios
Hi,
Are they always the same ones or different ones every time?
Have any liquids be spilled on the keyboard at all?
- de jayeff
Did you clean it?
- de NR26
Yes it always the same and no there's no liquid got into it
- de emad ayad
I don't know how to clean my keyboard from inside
- de emad ayad
