Saltar al contenido principal
La Canon AE-1 es una cámara de película réflex de objetivo único (SLR) de 35 mm para usar con lentes intercambiables.
Preguntas 30 Ver todo
Why are the batteries discharging so quickly?
A little backstory.. I bought this camera in Japan where quality of used equipment is generally pretty high. It has worked fantastically well for 4 years, then it suddenly starting eating batteries almost within a day. I bought a couple of different brand batteries but nothing has solved it. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Sounds like you have a capacitor going bad or it dried out. Though I'm not familiar with this camera so maybe get a teardown and look for bulging capacitors.
Fue útil esta respuesta?
Puntuación 0
As I remember, these use tantalum caps, so they are unlikely to be bad.
I used to repair these, but it has been many years, so I don't remember what the current drain problem (rare) was. I do know that working on SLRs requires much more than the usual "handiness" that many people have. Unwise use of solvents, brute force in opening, or even just touching some things can cause expensive damage.
You can get a service manual online (e.g., ++https://www.manualslib.com/download/7040..... If you are up for it, give it a try. You need electronics troubleshooting skills and equipment as well., Go slow, patience is your friend. If you take it to a camera repair shop, make sure it's a good one. Those are thin on the ground, it really depends on where you live.
Puntuación 0
You likely have a capicitor that needs replacing, or perhaps the motor drive is running (continually focusing) even if you aren't using the camera. If you put the battery in, and leave the camera off for several hours/days does the battery drain at all? I'd suggest taking your camera to a camera store or you could call Canon to see if they can repair it for your (as a mail in repair)
Puntuación 0
Añadir tu respuesta
clark photos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 25
Todo El Tiempo: 266
