Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Reparación y resolución de problemas del dispositivo para el portátil Dell Inspiron de 15 pulgadas con número de modelo 3567.
I hibernated my Inspiron and now it does not power back on
Hi All,
My Dell Inspiron is a fairly vanilla one with one exception that I replaced the factory provided hard drive with a WD Blue SSD. It had worked flawlessly since almost 6 months. But, this last time, instead of turning it off, I hibernated it and now it is plain dead. The laptop does not show any power even with battery and power adapter attached and it simply fails to show any life.
Not sure what has broken inside it and I even tried removing the battery and help the power button for a few seconds to drain the components of power as was suggested on a few blocks but to no avail.
If you have any idea on what I can do, please let me know. I am pretty sure there is nothing that could have short the motherboard but I could be wrong.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Disconnect both the primary and CMOS batteries, hold the power button for 1 minute, and try again. However, turn the laptop on before reinstalling either battery; that sometimes helps. If the CMOS battery is dead, it's easy to tell because it will boot normally and reset the BIOS to default settings.
However, disconnecting and reconnecting it (as well as the primary battery. Disconnect both to properly drain the CMOS RAM so it HAS TO go back to good defaults), which often acts as an immediate fix. I've even seen 7490s sold "as-is" due to this issue, so I once scored a $150 7490 with the 8350U/FHD LG IPS LCD :-). Mine isn't the top spec edition (that's a 4K IPS Touch/i7-8650U/32GB RAM/biggest SSD available from Dell out of the box. You rarely see these, but they exist). That said, I came from a bum with a dirty past (active lease where the machine was suspect, liquid damaged. I took what I could at that time.
Yes, I have seen 768p BOE TN ones (I have one as a throwaway with the 8250U) machines, but most have the LG IPS LCD or the BOE IPS LCD. The best units come with the LG part.
The permanent fix to this problem is a new CMOS battery, especially if it tests at 2.5V or lower, or is borderline (use a cheap multimeter; even a cheapo one from Walmart will work to check these batteries as they're low voltage). Follow this guide to open the laptop to reseat/replace the CMOS battery. On yours, if it's dead, you can use any off-the-shelf battery that is socketed and not one of the Dells with the wiring harness. Even then, the battery known to cause issues is so cheap it wouldn't hurt to change it to mitigate the issue completely. I consider it a consumable item like the primary battery once the computers known to have this problem enter the hands of DIYers at Walmart special prices, especially once the R2 facilities begin selling them off without SSDs.
Imagen de Dell Inspiron 15 3567 Batería
Guía
Dell Inspiron 15 3567 Reemplazo de batería
Dificultad:
Muy fácil
10 - 45 seconds
Imagen de Dell Inspiron 15 3567 Módulo de Memoria
Guía
Reemplazo del módulo de memoria Dell Inspiron 15 3567
Dificultad:
Fácil
1 - 3 minutes
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Abhishek Kapadia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 812
