Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Impresora de inyección de tinta inalámbrica multifunción (escáner/copia/fax), lanzada en 2013 por Canon. Identificado por el "MX922" en la parte frontal de la máquina, arriba y a la derecha del logotipo de "Canon".
Ghosting only on blacks, colors are okay
My Canon Pixma MX922 has a print ghosting problem only on the two black inks. Colors look good. Canon recommends cleaning the encoder/timing strip with IPA. I have done this multiple times with no performance change. Any ideas what the cause could be? Would a bad print head do this? Do I need to disassemble the printer to access and clean the encoder/timing read sensor?
Es esta una buena pregunta?
Puntuación 2
1 comentario
Hi @damon10 ,
Just curious if it does this when printing or scanning using the printer control panel or from a computer or both?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@damon10 yes, a partially clogged print head could be the issue. Check on here how to clean it
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I did throughly clean the print head. It did not fix the issue. I can try that again. It just wastes ink that has flowed from the ink cartridges into the reservoir of the print head. A few other people posted this same issue on Canon’s support sight. Canon’s response was clean the timing strip, which didn’t fit it for us.
- de
Añadir tu respuesta
DTG estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 1,137
