Saltar al contenido principal
Un PC de escritorio construido a partir de piezas de bricolaje listas para usar, en lugar de uno prefabricado de un fabricante importante. Estos también pueden ser construidos por un IS utilizando piezas listas para usar.
Preguntas 20 Ver todo
My pc chrashes every week in between.
Hey. So i have had this pc for around a year and this has been a common issue now. My pc chashes every once a week and when it crashes i need to unplug my graphics card and plug inte in again after around 10 minutes for the pc to work again. And then after a week it does the same. I have checked overheating which shouldnt be an issue. Basically what happens is that the screen goes wide black and everything crashes but the pc still running.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The software or work you are doing on your PC is not capable to handle your card. It is my personal opinion. Might possible your card is old and not enough to work with the latest updates on your software or games whatever you are using. It is also possible that at some point may crash your display because all other time it is working. It should not work any time if there is a card or PC issue.
One thing you cantry simply format your PC and try to check the problem still presists.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Lucas_86 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 48
