Saltar al contenido principal
Lanzado en octubre de 2013, este sistema de altavoces inalámbricos ofrecido por Bose se identifica fácilmente por un número de identificación de producto de 355589-1200.
Preguntas 11 Ver todo
Teardown | breaking of ribbon cables
I accidentally broke the ribbon cable while cleaning the front mesh panel. Can someone guide me through repair or can suggest exact specification for Ribbon cable attached to the cover of the speaker. ??
Is there any up-down or front-back, in-out port sequence .??
For your reference please refer to image in step 8 of Bose SoundTouch 20 Buttons Replacement .
Will highly appreciate any valuable advice.
Regards,
Amit Katiyar
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi Amit, I did the same thing. Are you still interested in getting some help with this problem? as I have learnt quite a bit about these ribbons as a result and successfully fixed LCD Display ribbon replacemnt.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi Amit , did you manage to get the replacement ribbon cables . If yes. kindly guide me . I am also facing the same issue . parveensalaria786@gmail.com . help will be appreciated .
- de
@parveenksalaria Please keep discussions on site rather than using private email; that way everyone can benefit from your learning rather than just one person.
- de
Añadir tu respuesta
Amit Katiyar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 107
