Keyboard partially working after battery replacement
Hi, I replaced the battery in a mid mbp but the keyboard has some keys that are not working at all and were working before.
Anyone has come across this issue?
Thank you!
NOTE: after a night turned off, turned it back on, still not working, 15 minutes after being, its working. I suspect a restart will break it again
NOTE 2: without turning it off, the cmd isnt working..
NOTE 3: all keys are working. Scared to restart…
Es esta una buena pregunta?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
I'm interested in the batteries temps when the keyboard works and when its not.
Is it only a few keys or the full keyboard failing? Open up the keyboard viewer so you can visually check each key: System Prefs > Keyboard > Show keyboard & emoji viewers in menu bar. Then using the menu select Keyboard viewer.
- de DanJ
Only a few keys but at the moment, the whole keyboard appear to be working. Yesterday many keys werent and this morning after fresh restart so I can drain the battery and plug it for 5 hours (calibration) keyboard was failing on some keys. Now after it was turned on for 2 hours, all keys appear to be working and I am afraid that if I reboot it will do it again.
edits: I dont think the viewer is available in big sur?
- de Karen
@karen12 - The view is there ;-}
Do you see the flag in the top right of the menu bar? If you do click on it.
- de DanJ
Oh yes! All keys are working on the viewer. At the moment all keys are working also. but it still happened to me twice that some keys arent working. I might try to reboot and see
- de Karen
