Face ID can not be activated after soldering i2C flex cable
Hello guys, I would like to get some help with a strange issue that I came across.
I have repaired an iPhone 11 and 11 Pro with FaceID issue. I will go through the process step by step. First I attached the original FaceID flex to the i2C programmer and read its values. After that I connected the new i2C and wrote the original flex values. Then I desoldered the chip from the flex, removed the mosfet and did the neccessary jumper. After that I soldered the chip to the new flex and attached it to the i2C programmer. The test showed pass, I also checked under camera and all 4 spots of the projector light up correctly. Being happy that I did a good job I assembled back everything and started the phone. Now I am greeted with a “FaceID can not be activated on this device” message. I was thinking maybe my flex is bad so I took a new i2C, copy and write the data, desolder the chip and resolder. Assembled back everything and the error still pops up. I thought okay lets solder the chip back to the original flex. Now the error is gone but ofcourse FaceID doesnt work. I have the same issue with an iPhone 11 and an iPhone 11 Pro. What do you think, what could be the issue? I did around 25 repairs before without any issues.
Es esta una buena pregunta?
2 comentarios
iphone Face ID can not be activated, it is not real damaged, or not working, jut is hibernate or Self protection from apple design, the new face id flex cable just wake up it
- de Yong Hui
A mi me sale todo bien con los 4 puntos, pero me dice iic abnormal, ya recibí el iPhone xr con el flex cambiado, ahora no se que flex es, pero en mi JC me da error de chip
Everything works fine for me with the 4 points, but it says iic abnormal, I already received the iPhone xr with the flex changed, now I don't know what flex it is, but on my JC it gives me a chip error
- de JJTech Morel
