iPhone 12 Pro Max cracked
My iPhone pro max has a battery problem which keeps turns of every minute and front screen and back has a crack ?
Es esta una buena pregunta?
Did you already replaced the battery ? If not, your battery is probably end-of-life. You can replace it following this guide : Reemplazo de la batería del iPhone 12 Pro Max
Regarding the crack in the front screen, the repair guide is here : Reemplazo de la pantalla del iPhone 12 Pro Max
Regarding the crack in the back, I would suggest to simply add a case for your phone (this will also protect it from further cracks. I would suggest to also add a screen protector (simply search for it on your prefer search engine / online retailer).
Hope this helps.
Guía
Dificultad:
Moderado
1 - 2 hours
Guía
Dificultad:
Moderado
1 - 2 hours
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 823
