Saltar al contenido principal
Why does the dishwasher fill and drain multiple times on cycle start?
Hello - This is model DUL200PKS1. Every thing is working fine with out any diagnostic lights, except for the unit filling and draining multiple times at the start of the cycle. Heating element works fine. It does complete the cycle, it just wastes heated water at the start of the cycle. I’ve checked the float switch and works fine. I don’t really want to swap parts without a good diagnosis, and would prefer to not buy new if it is repairable! Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
Hi @bostomw ,
Don't know the answer but if you haven't already done so, check behind the kickplate (toeplate?) and see if the tech sheet is there in a plastic sleeve. (Whirlpool part # LIT8533345 - can't find it online)
This will show you how to get into the dishwasher diagnostic test mode so that all the functions can be manually tested.
It will also give the causes for any diagnostic error codes that may be produced.
Hopefully it may even have a wiring diagram as well.
- de
Agregar un comentario
1 Respuesta
there are a couple of tech sheets here. not sure if they are the right ones but if there is diagnostic info on them it may be the same.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mike Boston estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 114
