Saltar al contenido principal
Released on July 24, 2019, The third generation Amazon Kindle Oasis features a 7-inch, 300ppi E Ink display, adjustable warm light, one-handed design, waterproofing, aluminum exterior, Bluetooth support and Micro USB for charging. This e-reader comes in two colors: Graphite or Champagne Gold.
Preguntas 3 Ver todo
Can a cracked screen be replaced on a kindle oasis?
Can a cracked screen be replaced on a kindle oasis? The kindle is working, text can be read pages turn etc., but the screen is cracked. Amazon would fix it if still in warranty but as it’s out of warranty they refuse and expect to buy new instead.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi @jacqui1234,
What is the model number of the tablet? (usually found on the back cover of the tablet)
- de
Hi @jayeff
Model number: S8IN4O
10th generation according to Amazon registration.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @jacqui1234
It may possibly be repaired but the problem is in finding the replacement parts.
I couldn't find any replacement parts at all for a Kindle S8IN40 (aka Kindle Oasis 3, Kindle Oasis 10th gen, Kindle Oasis (2019).
Also the only repair guide that I could find (and a failed one at that) was for a Oasis 9th Gen. This model certainly looks like that it wasn’t meant to be repaired.
Kindles are difficult with parts because each new model differs slightly from the previous, so parts aren’t readily interchangeable, between same series models or even different series e.g. Oasis, Paperwhite, Fire etc. That is why the model number is important and not just the model name as even “generations” can be confusing as to which one it exactly is.
Hopefully someone else may provide a better answer.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Thanks @jayeff, I really appreciate you looking into this. So frustrating that they’ve made this a disposable item.
- de
both 9th and 10th generation are exact same dimensions, so glass top would be identical, only difference is 10th gen oasis has amber colored lights.
I also would be interested in finding someone that can replace the glass top, unfortunately looks like they will all end up in the trash as I don't see anyone who has succeeded in doing this. Hope Right to repair may some day rectify this.
- de
@ciroz
You may have to be careful as even though the screen dimensions might be the same a lot of the time the screen flex cable connection is different between models.
- de
Añadir tu respuesta
Jacqui estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 70
Ultimos 30 días: 238
Todo El Tiempo: 3,800
