Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador i5 de doble núcleo A1418 / EMC 3068/2017 / 2.3 GHz. Lanzado en junio de 2017.
Can I upgrade the processor in this iMac?
I am doing work in Adobe premiere pro and after effects, I upgraded the ram to 32 GB but with this processor it is still too slow.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Sadly the CPU chip is soldered on your logic board in this series 21.5” iMac Core i5" 2.3 (Mid-2017)
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Is it possible to replace the logic board?
- de
While you physically could, what would you put in, this system was a single model in the iMac18,1 Series this is the last plain Retina model as such you would need to also replace the display as the next generation is using a 4K display iMac19,2
Frankly, the costs of this would make it much more expensive than just finding a used system ands selling yours to recoup some of the costs.
- de
The processor is soldered to the board so you cannot upgrade the processor. You will need equipment to do that, but it’s impossible
Puntuación 0
1 comentario:
Even if you had the equipment like dan says, You would need to replace the display too
- de
Añadir tu respuesta
Gary Baker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 269
