Fixed:MacBook superslow max 10w, 1.0GHZ , battery 0% due thermal paste
Hi, I would like to understand what happens here. In order to lower my MacBook Pro 15” mid 2014 (2gb GPU) cpu, usually 55-65c , 3000rpm (single monitor), 75c 4000rpm (dual 1080p) I decide to change thermal paste. I disconnected the battery cable, not not all pins at once, I pulled it from right to left. No damage on pins. I applied new thermal paste, than the nightmare started. First computer won’t boot. With magsafe pugged in it boots, but clearly slow. At login screen it shows 87% battery (non apple, 83 cycles only ), after logging it shows 0% not charging. Testing cpu scores it gives mediocre 200 single core, 700 multicore . I was before 900, 3800. Using intel power gadget, power never does above 10w, frequency core max 0.8, temp around 55c max. This is the third time I applied the thermal paste, the first using X pattern, it was 42, 44, never above 48c. I have no idea that is going on. I can clearly see performance loss, including video lag, switching workspaces, maximizing. Techtool pro 14 thinks everything is ok. except for battery. Tried to reset pram and smc with battery connected and disconnected. None work. One time computer turned on on battery with fans running crazy, I tested performance was bad but did not check for cpu and power informations. Any advice? Geekbench 5 cpu test does not raise temperature over 59c, nor fan speeds. Takes forever to finish. Previously I had it 3-4k easy on tasks. I see computer running slow even on right click. All happens after change cpu and gpu on my retina.
Tried to max out processor with yes to bit bucket, not help.
Please check my Geekbench full results: https://browser.geekbench.com/v5/cpu/117...
TG Pro Sensors:
Techtool Pro 14 - Passed all sensor tests.
Coconut Battery Info:
I have applied thermal past 5 times. In the 4th I put extra, so here are the pictures before apply the 5th time.
Cleanup and reapply:
Insulator removed, I can see apple thermal paste all over, they are the bigger chunks hardened paste. The one I applied was easy since it still soft just like when I applied. We can notice the Arctic Silver 5 color is a bit darker than original apple thermal paste.
Results after use CPUTune, turboboost enabled just for test. Not recommended since full speed fan tem got to 99c. https://browser.geekbench.com/v5/cpu/118...
Sensor tests - CPUTune on, turbo boost off.
Performance restored after battery replaced. According to my tests. yes apple throttle cpu and gpu performance if Macbook has no battery or poorly functional battery. Not sure how I damage. the battery had around 90 circles and was working before I disconnected sideways from the board.
Testes running on battery only:
https://browser.geekbench.com/v5/cpu/119...
https://browser.geekbench.com/v5/compute...
Passed on all Techtool Pro tests as well.
Es esta una buena pregunta?
3 comentarios
If you can lets run the onboard diagnostics. Reboot your system and press the D key to enter. let us know what errors you get.
Reference: Mac startup key combinations
FYI: Apple broke the onboard diagnostics with the newer firmware release so if you are running a newer macOS release diagnostics might not work. Then you'll need to buy this app TG Pro it offers some diagnostics which might be enough to figure things out. Post a snapshot of the main window so we can sell all of the sensors and the diagnostic window at the bottom Agregar imágenes a una pregunta existente
- de Dan
@danj
Hi Dan, thanks for super fast reply. Apple diagnostic does not help at all. Techtool reports everything working. I'm pretty sure it is not, even typing is slow sometimes. It seems like olde days on hackintosh without gpu support, sort of. I updated the question and included images. Appreciate your help. Thank you very much for your effort.
- de Arthur Mafra
@amafra - There is an anomilly with your battery which needs to be investigated., install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see.
- de Dan
