iMac is woking but screen is screwed
Hi all,
is there any way to fix this?
Update (12/17/2021)
OK I managed to make the external display work: the imac was running Linux, and the second screen attached to the mini displayport through an HDMI adapter get no signal. So I created a Mac OS X installation boot usb stick and booted by USB. When running the OS X installation program, the second screen attached to the mini displayport was running fine.
Therefore I think the problem is in the screen.
Es esta una buena pregunta?
Does anything happen if you connect an external display?
- de Andrew S
External monitor attached to the minidisplay port with a mini displayport to hdmi adapter says no signal.
- de Gennaro
@golivag - Your new test proved the internal display is bad, time for a new one.
Please score and accept my answer - Thanks!
- de Dan
