Why is my xbox overheating? (Red ring code: 4132)
This xbox has had quite a few problems. While it plugged in and turned on after getting it, the disc drive did not open or read discs. Today I finally took it apart, fixed the drive, and got it working, I made sure it could read games, and put it back together. After about five minutes of being on, it overheated, showing the two red lights on the front. I pressed the sensor button and eject button to get my error code, “4132” can anyone tell me information on what this code means or how I could fix it?
Es esta una buena pregunta?
9 comentarios
Can you take a picture of your Xbox 360 motherboard (just the top)? Agregar imágenes a una pregunta existente
- de Andrew S
@o0mcnugget0o 4132 is a secondary code. Do you have a primary E-Code? The two red light error is triggered by either CPU,CPU or Ram overheating. You did check your fan, heatsink and thermal paste already?
- de oldturkey03
Took the pictures you wanted, see anything unusual? @andrewsawesome
- de DJ Gunter
I haven't worked on an Xbox 360 before, how do I get the primary E-code? @oldturkey03
- de DJ Gunter
@o0mcnugget0o check on here on here It tells you how to get the e-code
- de oldturkey03
Mostrar 4 comentarios más
