Saltar al contenido principal
Guías de reparación y soporte para netbooks producidos por Asus, incluida la línea Eee PC.
Preguntas 20 Ver todo
How upgrade ssd for asus x560u
I want to know how i can upgrade the ssd sata
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Here’s a video that shows how to open the laptop and to replace the sata HDD with a sata SSD. HDD removal starts at ~3:46 minutes into the video.
Here’s a supplier of compatible replacement SSDs, (click on storage). It is only to show what is available, their cost and also that a 9.5mm adapter is required, no doubt to correctly position the SSD, as it will be thinner than the existing HDD.
Usually suppliers of SSD also link software so that you can clone your HDD to the SSD before replacement so that there will be a seamless transition, i.e. if you clone the SSD first and then install it, the laptop should start up immediately like before with the HDD.
You can also upgrade the memory (ram) up to 32GB i.e. 2 x 16GB modules, if you require even better performance
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Benzi Margolin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 221
