Saltar al contenido principal
Guías de reparación y soporte para ordenadores portátiles fabricados por MSI.
Preguntas 270 Ver todo
GF63 8RC-264US service manual
The LCD in my laptop seems to have gone out, but I doubt it since I had to secure the hinges and used JB weld for this time( just to see the outcome) and somehow the LCD had a slight pink tint to the video and then went out. I plugged in an external monitor and no video. So I’m undecided what this could be. MSI are jerks with giving out anything like a service manual and this is pretty unfair IMO since I cannot afford to have them fix it unless it was free, its not.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Long shot but try starting in safe mode just in case it is a driver problem.
No video on an external monitor as well indicates a motherboard problem. (presumably you remembered to press Fn + F2 to switch the display from the laptop to the external monitor).
The laptop has two graphics adapters i.e. one discrete Nvidia GPU and an Intel iGPU. It would be unusual for both to fail so that’s why it might be a motherboard problem.
With the laptop turned on and hopefully booted into the OS, try shining a torch at an angle close to the laptop screen to see if you can detect any images at all. They will be very faint if they are there, so trying this in a darkened room may help to see them.
If you can detect images then there is a backlight problem, but this is only for the laptop screen and not the external monitor.
What is the laptop’s motherboard’s board number? (printed on motherboard itself). The best way to hopefully find the schematics for the motherboard is to search for (insert motherboard board number) schematic, as these may be required to find out what’s wrong.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Greg Clark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 283
