Are temperature sensors on Mac Pro Late 2013 serviceable?
My MacPro Late 2013 was starting to run a little warmer to the touch than usual, so I ran TechTool Pro 14 which identified one of two temperature sensors to have failed.
Are the individual sensors serviceable and can anyone recommend a parts source?
If the sensors are bundled within a component assembly, would that component be the fan assembly and would the entire fan assembly need to be replaced, and again, would anyone have a recommendation for a source for the fan assembly?
Thank you.
Update (11/05/2021)
Good morning and thank you, Dan. I am located in the USA, to answer your first question.
In response to your first suggestion, I followed both methods that you mentioned. The onboard diagnostics came back reporting no problems, and TG Pro’s paid version also reported no problems. The screen shot is attached below.
I am at loss as to how and why TechTool Pro 14.1, running under MacOS 12.0.1, and my physical touch would point to a problem, but now two other software applications would contradict that. Any guidance and suggestion from anyone would be greatly appreciated.
Es esta una buena pregunta?
1 comentario
Where are you located Country? So we can aim you to a more local source for parts.
Without a firm idea what the sensor is telling you replacing the fan unit may not be the correct part.
- de Dan
