MacBook randomly crashes/shuts down.
One process name in Console > Crash Reports shows up for one date (photoanalysisd)
, but this happens every day. Shouldn’t there be Crash Reports every time this happens. I’m also not convinced this particular crash is the same kind of crash I’m experiencing daily.
I thought the issue was the battery, so I got the battery replaced but its still happening.
Log for photoanalysisd:
https://codepen.io/skyefromtexas/pen/jOL...
In my system log I will sometimes also get kernel AppleCredentialManager: powerStateWillChangeToGated: SYSTEM WILL SLEEP and then my computer will go to sleep for no reason.
EDIT: I used the terminal command to find out why the last few shutdowns occurred. The last one was around 12:35. Here is a screenshot:
And the codes:
Here’s what @Craig prompted me to enter in the terminal after shutting down:
@Craig suggested searching “panic”
Es esta una buena pregunta?
12 comentarios
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
- de Dan
HI @Dan. I uploaded the image to the original post. Thanks, Dan
- de Skye Thompson
@Skye Thompson - Good we know the battery & charging logic is working properly!
What is your SSD drive the original Apple unit or something else? Also, did you try booting up with a external bootable drive to see if that works without any issues.
- de Dan
@Dan - its the original Apple Drive. I can boot an external bootable USB, like Ubuntu, yes. But I didnt use it long enough to see if it crashes. Crashes are random, but usually occur at least after about 20-30 mins. Although I have had some crashes within 5 mins of use. I just had a crash at around 12:35:05 -give or take a few seconds. -- but it didn't show up in the Crash Report in Console
- de Skye Thompson
I found this in `system.log ` around the crash time:
https://codepen.io/skyefromtexas/pen/qBX...
EDIT: is there a different log I should be looking at when the crashes happen? Because Crash Reports show nothing.
- de Skye Thompson
Mostrar 7 comentarios más
