Laptop Screen shows Pink/Green Horizontal Lines at the TOP.
I was using it normally. out of nowhere, it appeared. If anyone has any fix or has faced this problem please let me know…!!!!
Es esta una buena pregunta?
Hi @kk8 ,
Connect an external monitor (TV?) to the laptop’s HDMI port and check if its display is OK. Don’t forget to press the appropriate keys to extend the video to the external display
If the external display is OK then the problem is either the video cable (eDP cable) between the motherboard and the LCD panel or more likely the LCD panel is faulty.
Here’s the owner manual for the laptop.
Go to p.38 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly.
Doing this will give access to the video cable so that it can be inspected for any damage, loose etc and also the LCD unit. (see p.43)
If it is determined that the LCD panel is faulty it will have to be replaced as it cannot be repaired. Replacement screens are available online. Just search for Dell Vostro 3568 LCD screen to get results for suppliers that suit you best. Sometimes the Dell part number can be found on the back of the LCD unit if you wish to verify that you’re ordering the correct one.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 755
