Saltar al contenido principal
La panificadora eléctrica Oster Expressbake CKSTBRTW20 fue lanzada en el 2009 y tiene una capacidad para hacer aproximadamente 1 kilo de pan en menos de una hora utilizando la función Expressbake.
Preguntas 3 Ver todo
Device has stopped mixing.
Hello! I recently picked this up at a thrift shop since I have always wanted to try one. I’ve used it 7 or 8 times and the last couple times the paddle would stop spinning to mix the ingredients. I thought it was due to gunk on the paddle or the inner container wasn’t inserted properly. This last time it mixed maybe two times and then would have an audible “click” sound instead of turning the paddle. Does anyone know how to fix the motor or attachment?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Andra Hutton could be the motor as well as the electronics. Let’s see what it looks like I suggest you start by disassembling it using something like this guide Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Make sure that mechanically it all looks okay. You can always post some of your devices images, with your QUESTION, while you do the work. that way we can see what you see and possibly assist you further. Let us know if you find some oddities etc. Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Oster Expressbake CKSTBRTW20 Inner Chamber
Guía
Dificultad:
Moderado
20 minutes
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Andra Hutton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 126
