01 - Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
02 - Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
03 - Drain Hose
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
https://www.repairclinic.com/RepairHelp/...
UPDATE
These are the most likely causes and solutions for a drn error code:
- Clogs: A blocked drain hose can prevent proper draining. Consult your user manual to determine how to disconnect the drain hose. Look for visible clogs and remove them before reconnecting the hose.
- Kinks: If the drain hose is kinked, it can limit the flow of water. Gently straighten any apparent kinks. If the hose is damaged as a result of kinking, it needs to be replaced.
- Incorrect installation: If the drain hose isn’t installed correctly, it won’t drain properly. Check your user manual to confirm that the installation is correct. Make sure the hose doesn’t extend more than 4.5″ into the standpipe and that its end is 36-96 inches above the floor.
5 comentarios
@teamnate your washer model is a MVWB765FW ? Just making sure....
- de oldturkey03
We are having the same issue! We have taken it apart 8 times, nothing is clogging it. Took the pump out and cleaned the filter. Nothing in it. Still have the same problem!!
- de Rachael Smith
Has anything resolved this problem? My washer is doing the same. It will not spin leaving the clothes sopping wet at the end of the cycle. I'm trying not to have to replace mine as it is about 6 years old as well. Just wondering if I should keep trying to repair it or just bite the bullet and but a new washing machine?
- de Daphni Shrieve
I can't even figure out how to get at the drain pump to check it!! Can't find any videos or manuals as to exactly how to get at it!😣
- de Tammy Lawyer
I had checked for blockages and checked the pump, everything is OK. The pump would run intermittent, then I tried moving wires while drain cycle and it started to pump the water out. I am trying to see if the connection on the pressure sensor connector at the CCU is the problem or the wire harness on the pressure sensor is the problem. Will try more test.
- de B Fong
