Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El iPhone convencional de Apple de 2020 se lanzó el 23 de octubre y viene con una pantalla OLED de 6,1", un sistema de cámara dual de 12 MP y en cinco colores disponibles. Sucesor del iPhone 11.
iPhone 12 battery replacement
hi, if i replace my iphone 12 battery with ifixit battery, does the battery health show up or not?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
No, if you replace the battery in an iPhone 12, battery health will stop working.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Does that mean that the % power remaining will not display in the upper right corner of the home screen on my iPhone 12, if I swap out the battery?
- de
@lenayres1a93233 No, that's the battery's charge percentage, which is completely separate from the health percentage. You'll still be able to see the remaining power in the corner of your screen after replacing the battery.
- de
i do not know 100% but knowing how APPLE is with their proprietary parts its kind of a gamble to expect that. ESPECIALLY Considering even OEM parts from THEM! dont work how theyre supposed to. IE the truetone feature when replacing with an OEM screen.
i hope this helps
Puntuación 0
It will not show but you can just Use 3utools to check your health with a computer. Why in the heck would you change the battery such a new phone
Puntuación 0
Battery health will not show, and you'll get a message showing that it can't confirm you have a genuine battery.
However, some places, (not many) will be able to spot weld the flex from your original battery to the replacement. Then reset the charge count.
Being so new, if there are problems with the battery, Apple should replace under a warranty seems most of the 12 range will still be under warranty.
Puntuación 0
1 comentario:
I have done it on XR, you can do it at home with spot welder. just buy battery cell for your iphone (without the flex and with more metal space to weld on). there are many tutorials on internet. after spot welding you have to reset the cycle count by icopy device.
My brand of the spot welder and icopy device is QianLi - you can buy it on aliexpress as well as me, its a little bit cheaper
- de
Añadir tu respuesta
Chris Rayn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 1,651
