My Dri-Eaz Defendair 500 wont turn on.
Dri-Eaz Defendair 500 wont turn on. Plug show power, but no noise when I turn on the switch
Es esta una buena pregunta?
Hi @craiggessell ,
Disconnect the power to the machine and then open it up an use an Ohmmeter to check if the 230V AC switch - part #80 has continuity, when operated. (or if you have the 115V AC model, the 115V AC switch - part #73 is OK - (here is the parts list for the 115V model).
If they’re OK then you may have to check the control board for any damage etc. There is no mention of a fuse in either parts list but that doesn’t mean that there isn’t one.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 307
