Saltar al contenido principal
The Lenovo ThinkPad E540 was released in August 2014. It can be identified by its model number: PF-01G2R9.
Preguntas 8 Ver todo
when boot up the red light at the I dot is on and the fan turns a whil
Pls help I have a lonovo e540 and when boot up the red light at the I dot is on and the fan turns a while and stop the hard drive runs but does not display any light on keyboard and there is no display
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Try a power refresh and see if this resolves the problem.
Turn off the laptop if on, and disconnect the charger if connected.
Remove the main battery from the laptop. (see p.66 of the (hardware maintenance manual)
Disconnect the RTC/CMOS coin cell battery from the motherboard, (see p.76 of the hmm). Whilst it is out measure its voltage. If it is <2.5V DC replace it with a new one.
Press and hold the laptop’s Power button for a full 30 seconds and then release it. This will dissipate any residual charge from the motherboard and restore any corrupted BIOS settings, that may be preventing a normal start, back to their factory default settings.
Reconnect the RTC battery, reassemble the laptop, reinsert the main battery, connect the charger and try to turn on the laptop.
If it turns on then there may be a message about the date and time being incorrect. Once it has been corrected the message won’t appear the next time the laptop is started.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Saomo Mana estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 658
