Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
iPhone 7 Stuck in Boot Loop
Hello there,
I have an iPhone 7 thats stuck in a boot loop after replacing the lightning cable. The phone has had some problems before so I’ve done past repairs such as a screen replacement and battery replacement. At some point the home button stopped working so it was used with assistive touch and it still worked. Eventually it stopped charging, so I replace the lightning port, first time it doesn’t charge so I return it and order a new one and install it, finally it starts charging again but is immediately stuck in a boot loop. First thing I try is replacing the battery with the old original Apple one it used to have, that didn’t work so I ordered a new battery and tried it but it still didn’t fix it. Would the issue be caused by some malfunctioning component such as the no working home button (despite the phone booting fine while it didn’t work before)? Or is the board dead? Could it be the new lightning port that I installed thats causing the problem? Any ideas?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
iPhone screen replacements can be a tricky thing, but you seem to know a thing or two. Are you still using the original home button? Also, have you tried resetting via the DFU mode?
- de
@minas Yes I'm using the original home button. Since its stuck in the boot loop I tried but haven't been able to boot into DFU mode.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
It will most likely be a parts problem. The first thing you need to try is disconnecting the top flex and see if it still boot-loops as this is the major cause on the 7 series. If it it’s still the same disconnect the home button flex and try. If that doesn’t work it will either be the charge port or battery.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I already tried booting with different combinations of flex cables connected and disconnected and nothing worked. Tested it with 3 different batteries and nothing worked either so I'll try replacing the charging port again. Thanks.
- de
I replaced the charging port again and its still in the boot loop. Dead logic board?
- de
Did you try hard reset your iPhone?
You may check solutions here, or refer to this thread: iPhone 7 Boot Loop Restore did not work
Puntuación 0
1 comentario:
I tried those already and it didn't work.
- de
Añadir tu respuesta
Thomas Metaxas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 195
