Phone Not charging Post wireless charging coil replacement
So replaced the charge coil. And now battery does not charge. very possible I broke something or have a connector in the wrong spot. Phone does turn on but No charge at all. Any suggestions?
I added the 2 pictures below 1 of the back of the charging coil and one of the phone. I am thinking something is NOT making contact correctly. I did replace the battery at the same time so may be an issue there. But ordered a second coil to see if I messed up the first just looking for possibilities and hoping it is simply I do not have a good connection.
Es esta una buena pregunta?
Does anyone know if Wirelesss charging coil is required. For wired charging to work?
- de GKJarhead
did u use the disassembly guide on this site?
to answer your question if the wireless charging is apart of that circuit, theres a chance that the corded option wont work as well. but dont quote me on that.
Ensamblaje de bobina de carga y antena NFC del Samsung Galaxy NFC
- de Logixal
Am not finding anything useful, but I replaced a wireless charging coil in an android before and accidentally ripped the ribbon for the battery temp sensor. Would power up and run fine but refused to charge.
- de brandon k
@logixal yes I followed that guide.
- de GKJarhead
Ok so new recommendation. If it does not charge after putting together. Try a different charger. Before tearing it apart again.
- de GKJarhead
