Saltar al contenido principal
El Bose SoundLink Color es un altavoz Bluetooth, diseñado como una alternativa más asequible y portátil al SoundLink Mini.
aux in is broken ,how can it be fixed
aux in is broken ,how can it be fixed ? do i need some Accessories
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
@boseman how is it broken? Is the connector physically broken or what is going on with your Bose?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@boseman take a look at this guide. Step 6 shows the port soldered onto the board. So it would not be easy. You could try and purchase a broken Bose SoundLink Color and harvest the port from it. Or you could possibly pigtail a separate input port (cable) to it. This will depend on your soldering skills etc. If you can, post some images of the damage (disassembled) with your question. For that use this guide. That would allow us to see what you see and possibly point out where to solder to.
Imagen de iFixit
Guía
Agregar imágenes a una pregunta existente
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Bose SoundLink Color Altavoces
Guía
Bose SoundLink Color Reemplazo de Altavoces
Dificultad:
Difícil
20 - 30 minutes
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I have uploaded several pictures of it.
Ccould you help me to see whether i can fix it by using the old aux and just fix it (not replace ),
- de
@boseman Looks like the walls on the jack have actually cracked. so that would not be something that can be fixed but would require some sort of replacement.
- de
Añadir tu respuesta
Kyle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 714
