Saltar al contenido principal
La Nikon Coolpix A900 es una cámara compacta y fácil de usar, con una pantalla ajustable que la hace fácil para diferentes ángulos de cámara y video.
Preguntas 7 Ver todo
please help my camera won’t let me click an answer
hi my camera is stuck on “choose time zone and set date and time” how do i get rid of this. it won’t let me click menu to cancel and it won’t let me choose an option please help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hi Ashley, have you got any solution for this problem cause I am also facing same issue.
- de
Agregar un comentario
1 Respuesta
Hi,
Try a power refresh and check if this resolves the problem.
Turn off the camera and then remove the battery from the camera. (see image)
Press and hold the camera’s Power On/Off button for a full 30 seconds and then release.
Reinsert the battery and try turning on the camera and adjusting the settings.
This may not work as there is a backup power supply (capacitor) on the motherboard that maintains the settings when the battery has been removed. If any data has been corrupted preventing normal operation a power refresh may not restore the data back to default. You can only try.
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
ashley smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 882
