Screen replacement for Sony VAIO Duo 11 SVD11213CXB
I need screen replacement for Sony VAIO Duo 11 SVD11213CXB, can anyone recommend a reliable replacement? tried for almost a year with no luck till now.
Es esta una buena pregunta?
Fue útil esta respuesta?
@jayeff Wow that is so overpriced, it is more expensive than the laptop worth, part# not matching though
If they're hard to get then most probably that is why the price is high. Seller's market. ;-)
Just curious. How did you find the part number from the link?
@jayeff there was some serial written below the price
I thought that that was the selIer's code and not the manufacturers but maybe you're right.
When searching using the number i.e. LCDS154 it doesn't give results for the screen by sale by anyone else except this seller.
Cheers
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 248
Have you still got the original? It should have a serial and model number on the bevel on the display once you disassembled it. You can re-order based on that.
- de honakrisi
I have the part# the item is not available, you have to find a suitable alternative from another manufacturer, that's why I am asking
- de George Boctor
