Hi @spiderjocky11 ,
The liquid contact indicators turning red means that water has entered the phone.
It may be that the screen will have to be replaced but you will know this better once you are satisfied that it has been cleaned properly first.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problems caused by corrosion Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in there also. The ends of any flex cables and their connectors need to be cleaned as well.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
2 comentarios
So I dropped my Samsung Galaxya71 uw 5g in the water at the time all I did was try to dry it off didn't have anything really to put it in and you really can't take the back off to take the battery out so I let it set for a couple days it turns on and everything I have to touch screen just doesn't work so I can't like put my password in or it doesn't register any thing I'm catching on the screen I've tried to reboot it things how it's locked how do I what do I do
- de Jordan Micheal
@Jordan Micheal
See the answer below.
The phone will have to be opened, either by you or a professional repairer.
It isn't going to fix itself. If anything the problems may get worse the longer that you leave it.
- de jayeff
