Saltar al contenido principal
The 6th generation of the Moto E smartphones. Model numbers XT2005-1, XT2005-3, XT2005-4, and XT2005-5.
Preguntas 13 Ver todo
Why is my volume thing poppin up when I type?
I dropped my phone in the toilet but when I got it out I blew all the water out and then it was working but now it's still working but when I get on a app or some the volume thing will pop up . And my phone want turn off it turn off wen it want to. What y'all think I should do ??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to prevent any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. If possible, do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. Also remove any shields that may be covering some components and clean under them as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit Motorola Moto E6 guides which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later. It isn’t going to fix itself.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
iiamtay Dudley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 21
