Saltar al contenido principal
Guías de reparación y soporte para PC de escritorio fabricadas por Lenovo.
Preguntas 97 Ver todo
My lenovo m700z screen blur and have horizontal lines. Is it fixable?
My all in one PC is ok 2 days ago. Then suddenly when i switched it on this morning, there are horizontal lines, and color seems like smudged and i cannot see the letters well unless i enlarged it 150%. Is this fixable? I have been asking around, most of them tell me it is not fixable and advice me to throw it away.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi,
Try starting the computer in safe mode and check the display.
If it is OK in safe mode it may be a driver problem.
If no good in safe mode either, connect an external monitor to the AIO’s DP port and check if its display is OK.
If it is OK then it is either a screen problem or a screen cable (LVDS) problem.
If it is not OK then it is a motherboard problem.
Here’s a link to the hardware maintenance manual that will help you to gain access to the LVDS cable to make sure that it is securely connected etc and also the LCD panel if it needs to be replaced.
If the LVDS cable is faulty the part number is 00PC931.
If the LCD panel is faulty then there are two parts numbers but it appears that they may be interchangeable. They are 01EF675 & 01EF674. You may be able to verify which one you have as sometimes the part number is printed on the back of the panel somewhere. .
To find suppliers simply search online by typing the part number only in the search box of your browser.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Yohn Hssn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 791
