Saltar al contenido principal
A1708 / EMC 3164: lanzado en junio de 2017, este MacBook Pro de nivel básico conserva sus teclas de función tradicionales (a diferencia de la barra táctil OLED).
Preguntas 563 Ver todo
Screen issues - white/negative screen fixes itself after update
I’m wondering if anyones had the same issue…..
One day I opened my laptop and the screen had gone almost completely white, with some flickering into negative when I moved the cursor around the screen. I could just about see what was on the screen. I took it into my local Apple Store and they said I need a new LCD screen.
I’d done some research and had heard of the faulty/too short Flex Gate cable, refusing to pay for a hardware fault.
I took the computer home and after a few days, It fixed itself!?!? It’s done this three times now, the most recent fix came after an update, with the computer left open for 24 hours.
How can this happen? Is it a faulty flex gate/LCD screen, or is it related more to software? Any guidance would be appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Here’s the details on FlexGate The Design Flaw Behind MacBook Pro’s “Stage Light” Effect and 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
As you can see the issue was strictly within the displays backlight cable,
What you are seeing is a very different problem!
In your case the issue is within the T-CON board which controls the scan of the image across the LCD panel. Apple had a second issue related to its systems cooling (2016 thru the current 2021 Intel models). Lets take a deeper look at what yours looks like
13” MacBook Pro Fn
13” MacBook Pro TB
So as we can see between the two 13” models Apple thought the lower clocking of the Fn models wouldn’t need as much cooling dropping one fan and cooling fin from the heat sink! While the TDP of the lower clocked CPU’s was lower the amount of margin was reduced too far! So the T-CON board can overheat if you loose the systems cooling as well as push the system too hard so the system can’t cool properly.
Once the display has started to fail the damage is done! The parts are now weaker so when you push your system it can show up more often. I’m suspecting you have a cold solder joint within the T-CON board or a failed capacitor from being cooked. Someone with the deeper micro soldering skills might be able to extend the systems life or I would just replace the display assembly.
So how can I prevent this from happening again?
The very first action I would do is make sure the system was clean of dust and debris from the fan and the heat sink fins as well as any dust build up on the logic board.
Next I would install a good thermal monitoring app which can also rev up the systems fan more effectively than Apples thermal model. The negative aspect of this is of course the fans noise! But you don’t need to max out the fan and pre-cooling things before you run a heavy process also makes sense!
This is what I use and recommend! TG Pro
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi, thanks so much for your answer, although I have to admit I’m pretty lost. I’m not IT minded, but I think I get the gist. But how did doing an update fix the issue? It slowly repaired itself over the course of 24 hours. I don’t push the system - its mostly used for streaming to be honest! Ive been transferring music to USB storage and its SO slow - related?
- de
@sandyriver - The OS update didn't really alter things here. Think of it this way I have a bottle of water which you empty out and put olive oil in it. The container didn't change only what it held. You more likely alter the systems thermals enough to effect the T-CON board. Think of it more like this your battery in your car is getting old so when it gets really cold your car won't start. Clearly the issue is the battery not the engine or lack of fuel.
What is your USB storage solution? What interface are you using USB-A, USB-C or Thunderbolt Each of these I/O standards offer different speeds and then we have the storage device its self HDD or SSD, single drive multiple drive setup in a RAID
Your system could also be limping (slow) as a thermal sensor is firing off. I would install this great App TG Pro it will allow you see more clearly what's going on. I would spend the few dollars for the full version to get the diagnostics. Take a snapshot of the main window of the app and post it here for us to see Agregar imágenes a una pregunta existente
- de
Añadir tu respuesta
Sandy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 67
