Presser foot does not lower
Presser foot does not lower and when raising foot, lever feels tight. Have oiled part. Does not help. If left long enough, about 5 minutes, presser foot will lower.
Es esta una buena pregunta?
Hi,
Don’t know about this machine but here’s the presser foot section from the service manual for a Bernini 930 that may help you to see what’s going on.
To check if the adjustment on your machine is correct you may have to improvise as I cannot find the “feeler gauge” mentioned in the manual but maybe you can place a 7.5mm object under the presser foot as described.
Sorry that I can’t be of more help on this.
Fue útil esta respuesta?
I will try suggestions and let you know in a few days. The machine is my Mom’s. Thank you!
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 247
Hi,
What is the make and model number of the sewing machine?
- de jayeff
Sorry! That info would have been helpful. It’s a Bernini Record 930 Electronic. Thanks!
- de Nancy Spooner
Bernina Record 930 Electronic
- de Nancy Spooner
That seems quite a niche market. On the bottom of the pedal there should be a type number lik 'Type 213' or 'Type 290'. Which one do you have?
- de gmantunt
