Replacement Hard drive type
Dear all,
my FusionDrive in my 27” iMac (Late 2015 IIRC) died, it briefly spins up and then down again, then the circle with line icon shows. Any attempt to fix this failed, so I am going to replace the drive. I ordered this kit here:
https://eustore.ifixit.com/products/imac...
without an SSD as I think I’ll go for a conventional HDD such as the WD Red editions I have running without issues in my NAS for years.
1.) Can I use any hard drive, or does the drive need a specific spec like regarding transfer rate?
2.) What is the HDD enclosure with USB in cable in the kit for?
Many thanks & best regards, Robin
Update (01/25/2021)
Hello Dan
Many thanks for your answer. Let me give some more detail. The 3TB Fusion Drive crashed on me and I do not want to go back to a fusion drive as I think it was a good solution back in the days were SSDs were expensive but today I think it’s a flawed design because there is no longer the need to have two systems (SSD and HDD) working together and sharing blocks of the same file. I do not want to fix my Fusion drive. I first wanted to sell the iMac as I bought a new iMac already. I therefore planned on putting a 500GB SSD in it. But I now have changed my mind and will keep the iMac for my man’s cave. I don’t need the speed of an SSD for that, so I therefore rather put a conventional WD Red CMR enterprise disk in it. So therefore more questions:
1) Can I use any 3.5” drive or is there some spec they need to specifically have? I have this one in mind.
2) Can I use the adapter cable that came with the kit? I suspect yes and stick the temp sensor near the center IIRC as in the manual on this site
3) I still wonder what that iFixit black enclosure with USB cable is for?
Many thanks and best regards, Robin
Es esta una buena pregunta?
6 comentarios
@rflight - Please cancel your order as this is not what you want.
- de Dan
@danj The kit is already here :-)
- de Robin Gottschalk
@rflight - Don't open it as you'll want to return it or you've wasted your money ;-{
I would just go with a 2.5" SSD at this point.
- de Dan
@danj Kit already opened lol, I always do that when parcels arrive lol. Ok let me buy an SSD then. Will this one work: https://www.digitec.ch/en/s1/product/sam...
@rflight - Thats a good drive!
- de Dan
Mostrar 1 comentario más
