Battery not charging after replacement
This weekend I replaced the battery in my MacBook Pro with a new ifixit battery. The MacBook had worked fine until recently, when it suddenly stated that the battery was not charging and needed replacing. Following on from this, it ran exceptionally slowly and would not boot at all at times.
I have replaced with a new battery, and it now turns on just fine (after an OS re-install), but is still saying that the battery is not charging. It now lists the following:
- Fully charged: No
- Charging: No
- Full Charge Capacity (mAh): 4698
- State of Charge (%): 1
- Cycle Count: 0
Could it be the new battery has an issue? Any advice would be kindly received.
Update - CoconutBattery image as requested -
Es esta una buena pregunta?
2 comentarios
While you have some on the needed information I need to see a bit more to figure this out.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
- de Dan
Hi Dan, have downloaded the app and added the image - hope this was what you needed to see
- de Richard Crampton
