Saltar al contenido principal
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Preguntas 17 Ver todo
How to remove management from school chromebook
I want to use my asus chromebook C202SC for stuff like youtube and stuff but i found out its managed by an extension called “GoGuardian” later on and i can’t uninstall it so i need to unenroll.I have tried ESC+REFRESH+POWER thingy but it is still managed so can somebody help me? I have to do this because at the end of my school i will give it to my younger brother so he can use it for gaming but all websites are blocked.Please help? If so then thanks!
-Nik
Es esta una buena pregunta?
Puntuación 61
11 comentarios
I have the answer.
- de
This works up to 2022. Press Esc, Refresh, and Power; Next press Ctrl-d, next press enter than press enter again and done.
- de
how to do it in 2023 please!!!
- de
ctrl refresh power then ctrl d then enter or space
- de
its not working
- de
Mostrar 6 comentarios más
Agregar un comentario
7 Respuestas
Solución Elegida
why are yall lying to these kids? that’s rude. if you open up the back of ur pc there is a lil white square box. remove that then just simply reset the chromebook. bada bing. one love tee
Fue útil esta respuesta?
Puntuación 18
13 comentarios:
thank you ma'ma or...sir thats very helpful of you lol and i have no clue why they lying like dat any who- thx again?
- de
does this actually work cuzzzzz im so sick of this
- de
does this still work i must know what is the white box in the back my chromebook doesnt have that
- de
What is the white box, it doesn't do anything
- de
ima check ok bois
- de
Mostrar 8 comentarios más
Nikolas Castillo you cannot the enrollment without access to the admin console under which your Chromebook was enrolled. You cannot enter developer mode without your administrators permission. That means you will need the credentials for those administrators otherwise it’s a no go. Of course you can check on here My chromebook has an admin on it, how do I remove it? for more info
Puntuación 15
5 comentarios:
Can I do something with the memory chip to remove all admin data?
- de
Nikolas Castillo sorry but that is a no as well. There is nothing you can do without the admin login.
- de
its still managed and i am on summer break
- de
maybye i can do what tryhard.tech said i could ask them
- de
Once you leave your school or workplace, they will remove the administrator from the chormebook
- de
Sorry to break this to you but it’s pretty much impossible the chromebook is most likely managed by you’re school, and there’s only 2 solutions. 1:Contact you’re districts IT department and ask them to untie the enrollment. 2: or if you’re really tech savvy then you can change the device’s serial number breaking the admin's control which you probably cannot accomplish.
Puntuación 4
5 comentarios:
whats a cereal number?
- de
JK i know what a serial number is.
- de
all i know is you order replacements on it
- de
but i had no clue you could change it
- de
@Nikolas Castillo It's possible if you know how to soldier well.
- de
Try making a Ubuntu USB stick with another PC and make it bootable with something like Rufus. After that, plug it in to the Asus and shut the chrome book down. Now, press POWER and start pressing F12 right away.
It should boot to the Ubuntu boot loader.
If this is a Chromebook you bought: Install Ubuntu and erase the HDD
If this is a school issued device: Use the Try Ubuntu option.
If they somehow locked the boot Menu, I don’t know what else you can do other than replace the OS
Puntuación 2
ESC+REFRESH+POWER worked for me i just did it but at school and they dont give out the wifi so i dont know if it will work
Puntuación 2
First, powerwash the chromebook. Sign into the internet and when you get to the screen where it says “Getting device configuration” click the notification center in the bottom right corner and get ready to turn off the wi-fi. When the screen turns to “Enrolling device” Turn off the internet. It will say “Enrollment Failed” Then click the button “Enroll manually” This should pull up a screen saying “no internet”. Turn the internet back on and click the back button. Eventually, in the bottom left corner, buttons will start to appear. First, Apps (If your district has apps). Second, Browse as Guest. When Browse as guest appears, go back and forth clicking the back button and the Browse as Guest button. Eventually, the chromebook should crash when you click browse as guest. Finally, press esc + refresh + power and it will take you to a screen where it says “Chrome OS is missing or Damaged” Press Ctrl + Search (Ctrl +Shift on older models) and then press enter to go into developer mode. Then, the screen will say “OS Verification is off. Press space to enable” Press space to enable then press enter. Finally, the chromebook will reboot and the enrollment should go away. If it doesnt work, then try it again.
Puntuación 1
3 comentarios:
Does this work?
- de
I have already downloaded my entire Chromebook in caseof emergency.
- de
i am mangaged by my admistor too.
Puntuación 0
Añadir tu respuesta
Nikolas Castillo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 180
Ultimos 7 días: 1,140
Ultimos 30 días: 5,252
Todo El Tiempo: 30,813
