unable to change 51
How do i fix unable to change 51 on MFC 440cn
Es esta una buena pregunta?
Hi,
Do you mean an unable to print error 51?
Here’s a link that may be of some help.
I realize that it is not the same model printer but it still may be worth checking in your model as usually manufacturers don’t change their error codes that often so the error code usually means the same fault symptom but it may not have to be the same problem that caused it to happen
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 618
