Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Can the battery remain connected when replacing screen adhesive?
Hi everyone,
On every each tutorial I come across to replace screen or anything else I noticed that the battery must be disconnected before unplugging the screen or anything else.
Hence I don’t quite understand why can the battery can remain connected while the screen is unplugged when replace the screen adhesive? Am I missing something? What should I beware of when doing this?
Thank you very much !
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It is the plunging and unplugging of connectors that can blow the fuses that are soldered on the logic board. So it is ok to have the battery plugged in while you are not plugging or unplugging a connector.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you very much :)
So I just need to be careful that the connectors are right in front of their slot when I plug them back in? And obviously unplugged them gently.
- de
Añadir tu respuesta
KasDing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 44
