How to I do a factory reset, I tried the power and the +volume
I tried to reset n unable to change the password how do I do a factory reset
Es esta una buena pregunta?
To reset the device, there is a reset button located on the bottom of the device located next to the mic. To activate the button you must stick a pin into the hole where the reset button is located.
Fue útil esta respuesta?
Hi,
Did you do it this way?
Press and hold Volume + button and the Power button at the same time.
The tablet’s screen should turn on.
When it does release the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
Nothing happened still won't turn on
Does the tablet show that it is charging when the charger is connected?
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 108
Todo El Tiempo: 1,314
