Screen flickering and touch pad not working
My screen started flickering and the touch pad is not working(but working with a mouse) when it does that. The weirdest part is it works well one day and if I restart next day it will flicker continuously and never stops.
I tried the following things.
1. Resetting NVRAM and SMC but No luck.
2. Run it in safe mode but it still doesn’t solve the problem.
3. Ran the diagnostic and it says everything is good :(
4. Cleaned almost all of the software except chrome and adobe.
I am not sure what steps should I take next ? Is it coz of overheating or may be the some sort of loose connection between the board and screen ?
edit :
the camera is also not working when the screen is flickering
Es esta una buena pregunta?
2 comentarios
You'll need to see if the problem is present using an external monitor using a Mini DisplayPort or Thunderbolt dongle to what ever your display uses.
- de Dan
Hey Dan! Thanks for responding. I tried connecting it to external monitors and everything is working fine in those monitors. It’s just my Mac screen is having the same problem.
- de Sarvesh Rawat
